I will assembling a pro4896 router and the typical way is steppers and geckos. I have had a lot of problems with steppers in the past and converted mills and lathes to servos and snapamps and we've all been happy.
First, does a dual motor axis work well with servos compared to steppers? Will they both be at the same place on each side instead of fighting a little and twisting the gantry?
The machine has impressive Rapids of 1200ipm and I would like to match that if I go servo. But the torque, holding I guess, of the motor the vendor sells is 960oz in. To match that with servos gets into amperages that exceed the snapamp based on the motors I have found. But maybe 960oz-in is overkill and a weaker servo would be right.
The machine uses rack and the motors have a belt reduction to the pinion.
